281 - 300 of 510 Posts
Discussion starter · #283 ·
1. You need to enable Green Menu, there's a script on this forum for download, or You can do it via VCDS.
2. Then delete NAV partition in this Green Menu.
3. Download and install 6.32.1 maps, they are somewhere here also.
4. Install 6.36.0 maps in User defined mode.
NAV will start.
NAV will start.
I managed to get in the green menu.
There is no 6.32.1 map fil to copy…
i can delete the nav partition i guess…
Discussion starter · #292 ·
And we should now guess what happened exactly?
First of all delete NAV partition properly. You enter deleting section, and as You can read there, You need to enter it again for the process to begin.
Then edit metafile2.txt in the root folder, and add these two lines in the [common] section:
skipMetaCRC = "true"
EnableUserDefinedSWDLMode = "true"
Then start maps update in User defined mode and tick everything to Y (VW_ECE, Persitence, MapStyles and TMC sections must all have Y status before an upload). If You'll follow the instructions the NAV will start.
Then make and update with 6.36.0 maps in User defined mode the same way You did 6.32.1. Your maps will be up to date.
Tried brand new 32GB SanDisk sd card, copied files on Windows computer, keep Engine Running while update, still same faillure…
Error Code 160 on component "Database - LABEL" usually means the Updater process cannot find the LABEL folder (or its contents) in the pkgdb folder of the SD card. We do not know for certain what Error Code 146 means. We think "140" is a general I/O error reading the SD card and "141" means the source file is corrupted (usually due to extraction error). --g
Discussion starter · #297 ·
You have the same errors because You're making the same mistakes. And left us with guessing which one is it.
1. Did You make any tries with updating a firmware before the maps? Simply answer Yes or No
2. Download to the Windows PC computer archive 2017 - 7P6051236BS.rar from MEGA
3. Use WinRAR to extract in into HDD, it will check checksums
4. Format SD Card with full mode (not quick one) using default unit size
5. Copy extracted files direclty to the root of the SD Card
6. Edit metafile2.txt as mentioned above
7. Enter Green Menu, delete NAV partition (enter menu TWICE)
8. Plug on BATTERY CHARGER. Engine running with battery at idle with 12,0V or lower will NOT help, you will get errors.
9. Remove EVERYTHING from the glovebox unit, unpair Your BT, remove DVD, unplug AMI/USB, remove SIM and other SD Card
10. Start maps update with User defined mode.
11. If You haven't make a change with a firmware before and you COMPLETELY WILL FOLLOW given instuctions, and the update fails, use second SD Card socket. If it fails again, it means You do have faulty Main Unit. There is no alternative. Then diagnosis with VCDS is a must.
12. If You previously made a firmware upgrade it is very probable that You did it wrong.
Hello colleagues,
I am also about to update the maps on my Touareg 7P MY2014 from 6.28.1 to 6.36.0 (fw. 0824).
Just a few question to recap, ( I read all pages of this thread):
1. Can I update directly form 6.28.1 to 6.36.0, no need to intermediate 6.33/34 version?
2. Will (re)activation be necessary?
3. I understood that the offline special destination will be empty?
4. Will online POI search still work using google services?
5. Will I need to reactivate google services?
6. Will google earth overlay still work?
7. Are there any route calculation problems, some people claimed that the routing engine is damaged due to Audi maps on Touareg unit.
Hello there,
I've just updated my maps from 5.13.8 to 6.36.0
The procedure was following -
1.Erase via Green Menu old maps
2. Instal maps from the file that was provided
3. Used map activation script from here
4. Erased 2 errors (1 with script, 2nd via VCDS)
So far do not see obvious bugs,
Maybe what's a bit lagging - is the sea level meters, not showing at all, or showing 0, while there there are definetely some more meters.
Didn't seen POI, and still having issue, that Sign Reading not available in the area (I am in Latvia)
