261 - 280 of 510 Posts
The log file:
[INFO] Start: Thu Jan 01 00:02:43 UTC 1970; Timestamp: 20240311_190844
[INFO] mkaciosdb-v231231
ls: No such file or directory (MMI3GP_*.pkg)
[INFO] Cannot find navigation database release PKG file.
[INFO] End: Thu Jan 01 00:02:44 UTC 1970; Timestamp: 20240311_190845
image not found
Yeah, "Can't find PKG file" is another reason why nav will not initialize. So next you need to work with @Lysy to solve that problem (which may solve the nav initializing problem, anyway). --g
Would you know what the error code 140 means?
Not specifically. But we do know that Error code 150 means the Updater process cannot write to the destination device, either because no free space left or the device is mounted read-only. Which is why Retry often works with "140" type errors. --g
Discussion starter · #266 ·
My experience says that most of the errors 129, 140, 150 are when You do have a bad battery. Mine is showing now 11,8V at rest, and I had problems with maps upload, which occurred never before. This time I didnt use a charger.
Guessing 140 is the read error.
Just to make sure I'll buy a new battery and upload maps again to check it.
The upgrade instructions I received with my updates advised that a smart charger be attached during the update procedure to prevent the battery volts dropping during the process.
I did start the update again with running engine.
[INFO] Start: Thu Jan 01 00:02:19 UTC 1970; Timestamp: 20240312_095802
[INFO] End: Thu Jan 01 00:02:19 UTC 1970; Timestamp: 20240312_095802
image not found
Discussion starter · #270 ·
You don't need to run script rebuilding acios_db.ini
You need to run proper maps upload process with FAT32 card, with files extracted to root directory on not MacOS.
Well, I managed to get a windows computer and format the sd to fat32 and extract the rar file to
the sd, but still not working…
Should I move all folders in the root? Instead of pkgdb?
Discussion starter · #274 ·
The window on the right is ok. What exactly isn't working? You entered engineering menu, uploaded maps with User defined mode with ticking everything to Y?
Discussion starter · #278 ·
2 hours. On the first picture MapStyles should have Y status. It's very probable that You've made a Standard maps update first, it was very quick and made an update of only that section. Now You'll have Your NAV corrupted, even after full maps upload... Maybe acios_db.ini script will fix it.
[INFO] Start: Thu Jan 01 00:25:38 UTC 1970; Timestamp: 20240314_113236
[INFO] End: Thu Jan 01 00:25:38 UTC 1970; Timestamp: 20240314_113236
image not found
