I've been searching around and can not find a solid answer/guide. I found a thread started in March of 2020, but it received no responses despite getting over 600 views.
www.clubtouareg.com
Does anyone know if the VVT solenoid can be changed without disassembling the engine?
I don't have a CEL light on or any DTC's.
I did, not long ago use BG 109 to remove any sludge buildup in the engine before my last oil change. I would like to remove the VVT solenoid to clean any "particulates" that might have attached to the screen(s) of the unit.
Any help is appreciated. Thanks.
Camshaft Solenoid VVT replacement - 2014 Touareg VR6
Has anyone replaced a VVT valve/ camshaft position solenoid on a VR6 ? Is it possible to remove/replace these units with without pulling the engine? Any other things to watch out for? Thank you-
