That is what those Sonnax kits are. Better than original valves that won't wear out and go to crap like the stock ones.
Here is the one you need for $659
09D TR60SN OEM Updated Valve Body 2005-2010 Without Pressure Switches
Core Return Required
Complete Disassembly
Thorough Hand Washed Cleansing Process Removes all metal and clutch particles
Hand Assembled by Qualified and Caring Professionals!!
Aqueous Solvent Cleaning
Mounting Surface Verified and Flat Filed If Needed
Threads Checked and Repaired if Needed
Sonnax Updated Shift Valves
Sonnax Updated Regulator Valves
Sonnax Updated TCC Valves
Sonnax Updated Solenoid Modulator Valves
Rebuilt New Design Shift Solenoids With New Aluminum Housings
New Custom Machined Solenoid Bushings
Solenoids Graphically Tested on our Zoom SolX Solenoid Tester
Computer Matched and Flow Tested Shift Solenoids
Complete Computerized Testing Of Valve Body on Our Zoom VBT4000 Valve Body Dyno
Pan Gasket and Filter NOT INCLUDED
Make: VW, Audi
Model: Touareg, Q5, Q7
Year: 2005, 2006, 2007, 2008, 2009, 2010
Engine: 3.2L, 4.2L, 4.8L
