Ok so I have hird all about this VAG-COM stuff. What do I need to use it? And what can you do with it on a 2012 Treg? I have NO idea on how to do this stuff. Thanks!
That's a odb2 code reader not a vag com. A vag com connects to the VCDS software for advanced diagnostics of Audi /VW cars and allows you to change parameters etcThe reader - when you plug it in dont you just see the code on the screen? why do you ned a PC? I took my car into a indie garage yesterday - was plugged in - he read the code there and then off the reader - no PC involved - if that brings up a code cant you then just source the fault off the net from that code? Thanks
Me too. I have a warranty and would not want to do anything to void that.If you were to change even 1 parameter like increasing turn signal blinks or the trany to ROW to show gear display, could the dealer deny any type of warranty work for "tampering" with the initial settings. My Reg is brand new and would hate to jeopardize a warranty situation.
Most dealers wouldn't even notice the difference and how are they going to find out. If asked you could tell them another dealer changed it for you. It is obviously a dealer changeable item.If you were to change even 1 parameter like increasing turn signal blinks or the trany to ROW to show gear display, could the dealer deny any type of warranty work for "tampering" with the initial settings. My Reg is brand new and would hate to jeopardize a warranty situation.
