2005 V8, 55k miles.
Has all the symptoms of bad coolant sensors. Fan runs for about 15 minutes on strong high speed after a shutoff, eventually kills battery.
Hooked it up and the two codes it threw were:
P0106
P3081=low engine temp, (possible bad coolant sensor)
Started car up after replacements, Check Engine light is on, and the fan is still running strong after a shutoff.
Questions:
Do I have to clear the computer's fault codes? One older post said you have to do that to get the fan back to normal. Is that possibly why it is not acting normal after the repair? I understand it could be the thermostat too, But I really thought it was the sensors. Temperature gauge is working fine.
Any advice would be appreciated.
P0106
Questions:
