Tunes and hardware on sale
8.7K views 101 replies 13 participants last post by  TouaregHauler2021
Tunes and hardware are on sale right now. I'm going to grab them both and sit on them until my dieselgate warranty is over in October. I won't reach the mileage by then, so I'll time out.
I'm going straight to Tunezilla for my tune and I'll be getting the Rawtek DPF delete kit. Tunes straight from Tunezilla are much cheaper than Rawtek or Tune My Euro.
Are you going with a Stage 2? For the money from TZ, you might as well. I was thinking of the Eco from Rawtek since the Treg does what I need with the current power level. Not sure why I decided to check TZ directly but I'm glad I did. Under $800 for the Stage 2 tune for me.
Great question. Important to capture all the above except the cat to keep stink and smoke down, assuming you're willing to replace the cat every so often
I'm deleting DPF/AdBlue, NOx filter after DPF, and EGR. I'm debating about the swirl flaps. EGR will definitely be coded out and removed at some point. The downpipe will remain in place with the first cat.
Swirl flaps WILL fail. It's a matter of when. The EGR physically in place WILL cause issues, even catastrophically
New here and to this topic, could someone please explain how it's possible to do deletes without repercussions in the US? Is there no Diesel smog test in some states? I'm in CA, which I assume precludes any of those extra fun factor things... TIA.
Nope you're hosed
Not everyone can find "value" in spending $3k on deletes\tunes if the current hardware is fully functioning.
It takes a lot of driving to get ROI on that sort of "upgrade".....
Agree. I've left every emissions system intact, but once the warranty is up, I buy the parts and keep them on hand for the first time I pop cel for them, then they're gone. It's just too risky keeping them around, knowing they WILL break again, and again, and again.
I noticed on one of my customers CATA engined Treg that even though the dual intake flaps were coded out they still operated until you physically unplugged them. I believe his was a stage 2.
I also kept my DOC downpipe standard, it really brings the diesel smell down after a minute or two. Also apart from when your going full tilt, you won't notice anything smell or smoke wise which gives you a bit more stealth in your delete. Cops are really starting to crack down on smoking diesels
Thanks guys, it's what I thought. Lucky you.
Since we're on topic, has anyone here done the Malone/Tunezilla TCU tune and found it worth it?
It looks sensible in combination with a stage 2, as the transmission was also modified after Dieselgate, but the price is just too rich for my blood at the moment.
Or does someone know how to do the mentioned 'pre-diesel gate reflash' by other means?
The pre dieselgate transmission flash makes a decent difference, to me it seemed to rid some of the delayed response and hold gears a little longer in sport mode.
Supposedly tunezilla took it a step further, I know a couple of stage 2 cayennes on rennlist installed it and after some revisions really enjoy it.
I have the TCU flash from tunezilla. It's okay.
I wouldn't say it left me impressed that's for sure. I have stage 2 so maybe it overshadowed the upgrade. Does engage firmer and quicker for sure so there's no longer bigggggggg delay between shifts. However A DSG flash is night and day difference in comparison but we're comparing apples to sausages.
With a cat delete, dpf delete and muffler delete, it will be loud no doubt. Thankfully MOST of the noise will be out of the rear of the car though
The first cat after the turbo, in the downpipe, is what we are referring to as the DOC, correct? Why would it matter if the stuff after it is there or not? The EGR is the only thing I could see affecting it, but even then, not really. It's not like the treated gasses go back to the turbo to be sent back through the DOC and they are now cleaner and "easier to digest". Does a tune really let the engine emit more nasties? Other than the EGR not being functional, I don't see how it would amount to much more. A little extra fuel here or there, sure, but you're not "rolling coal" constantly.
If I'm misunderstanding the system, please enlighten me. First-time diesel owner here, but I do understand automobiles in general.
Yes, that's the DOC (cat) we are talking about.
It gets "raw" exhaust... so all soot, particulates, oil, blow-by, fuel, etc.... everything that results from the combustion.
As power goes up, more emissions of all those things will result.
So it will be processing that much more stuff\flow\volume, and since it relies just on internal materials\coatings to perform the reaction, it had a finite lifespan.
What is or isn't down stream of it won't matter for this "discussion".
Think of a typical cat on a gasser.... it needs replacing at 200k or whatever... same idea
#33 ·
DOCs are designed to last nearly as long as the vehicle. Lots of tdis driving around on their originals, 4 and 6 cylinders. Some over 600k
Unless they get 'poisoned' or clogged they are a passive emissions control which doesn't really 'wear out'. I've seen the ceramic break but that's from outside damage like exhaust hitting a curb etc.
Deleting DPF allows way more PM2.5 which can damage lungs in large concentration, isn't an issue if your highway driving. The NOx and its various counterparts are also pretty bad in large concentrations when you delete the SCR system.
Agree, however, both fuel & oil are contaminants that cause the DOC to experience way higher temps..... not to mention that the new increased\sustained +100°C EGTeeezzzz limits add that much more heat to the "system"......
We have seen\heard of VW replacing OEM DOCs on dieselgate vehicles, so they definitely aren't lifetime in the application discussed here.
#36 ·
High temps and contaminants chip/erode away the ceramic bit by bit.
A car that uses a DPF and requires an active regen requires fuel to hit the DOC to create the high temperatures required to get dpf to burn off
If you have deleted you won't be seeing those conditions nowhere near as often as the only time you will get excess fuel is on hard acceleration.
#43 ·
I'll lean into it a few times when I first get it done I'm sure, but I don't floor it often now. Being one of the poors with a $60K luxury German SUV, I have to save money for high dollar repairs and high diesel prices. :p
I'm not getting a stage 2 tune because I need more power (cue Tim Taylor) but because I want to delete and I need a tune to delete. I almost went with a stock/eco tune but the price difference was such that I went ahead with the stage 2. I don't plan on driving in S (I don't now, and that would be the poor man's tune simulator for me at the moment), nor do I plan to drive like my wife - foot to floor with whichever pedal her foot is on (I call her a digital driver, like most women, ON or OFF) - so it really won't matter that I have a stage 2 tune. I want more reliability due to the high dollar replacement parts being gone, and potentially better fuel economy. The added HP and torque will be a bonus. I may not be the norm, but that's how I drive now and plan to drive after the tune.
#49 ·
You and I are in the same boat lololol. I usually mod the hell out of my cars but I’ve been resisting to keep money saved for maint and repairs for the T.
Though diesel has become reasonable again. I pay less tha $4… I’m happy.
#47 ·
And for fun, here's how they fluctuate due to all those things, throughout all the readings I've taken over the last year during my routine scans\maintenance\PM\whatever that I've saved. So this covers all my use.... summer, winter, daily, towing, whatever.....
Code:
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 587 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 997 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 630 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 685 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 681 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 714 km
  IDE06983-MAS05392   Diesel emissions re-treatment: status-Average distance between DPF regenerations 533 km
#50 ·
I also agree the NOx is way worse. But our tdis are just a drop in the ocean.
Not going to turn this into an emissions debate but I found amount of NOx a single container ship generates running bunker fuel in one day is equally to every single VW tdi in North America running in cheat mode in a average year. It's crazy. And do you realize how many ships come I to docks in North America in an average day?
And then there's air travel....and gas heating systems.....off-road equipment.....trains.....
I believe dieselgate was political as well as sending a message to the rest of auto manufacturers that they are being watched.
#51 ·
okay… this does make me feel better, and I have also considered this. I mean **** - did my diesel school bus have a DPF, EGR, and SCR??? I was around those things pretty constantly till high school… as I imagine most public school educated people are.
