I have a 2013 TDI Touareg that has a Malone stage 2 delete kit installed . I have done the TCM back to stock swap with Yorktreg. However I am randomly experiencing a hard shift.... sometimes in the early gears , sometimes in the last gears. It is a rather intermittent issue, sometimes like it is searching for the next gear , then the last gear. Like it has hic ups. (I have sent my PCM back to Yorktreg asking him to swap me one more time which he graciously did) Still the same intermittent issue. Some days all is fine, the next day it hic ups again. If I do a trans relearn it seems to fix it for some days. Does my treg have some issue with TCM relearn? Maybe I’m not doing it correctly? I usually just turn the key on without starting it, hold the throttle pedal all the way down holding it for 15-20 seconds. Let off accelerator , turn key off. Pull key out. Wait 5 seconds. Reinsert key and drive. Shifts beautiful, including engine braking feature! I love it ...... that is till the hic-cups come back days later once again? What could be wrong? I checked with VCD’s , NO CODES! Can someone help me please?
Stumped in Va.
Stumped in Va.
