oh, there are problems I know... this is just where I'm currently working.. [e.g. other things include: the driver door latch electronics sometimes think they're locked so I have an emergency ziptie to pull the trigger, passenger window doesn't move (visible wiring issue), rear door is (mechanically) sticky - versus the driver door that is electronically sticky.]
Just a fun little investigation - sometimes I break out the multimeter...
Yes, I've got a DiagLink that tells me presumably as much as VCDS [notably, I have a cable.. just haven't installed VCDS because I have never needed it..] Diaglink tells me the issues all over the place, by system, like in the tranny section I get "impossible tiptronic signal" (or something to that effect), and all the other things.. much of which trip when the battery gets low [I suspect alternator because it's after a long drive in traffic that it trips out]..
I just wanted to check if low fluid was causing it to be: slow to shift into drive after I back out, sometimes it doesn't fully "click", sometimes it thinks it's in 5th, things like that.. In my experience (mostly Japanese) that is the kind of thing that I would check the "lifetime perfect" fluid on...
p.s. this is my sister's car and she doesn't need it and I'm just tooling around with it -- just in case the temporary ziptie thing was alarming..
