Hi all,
I'm nearly at the end of finally getting my T'reg to tow my boat trailer. It has been quite a journey - hopefully in this instance the destination is more enjoyable than the journey!
My boat trailer has hydraulic brakes that are powered by a Hydrastar HBA-12 unit.
I have installed the Brake Control Module (Hayes Energizer III) using the wirinig harness under the dash. I can confirm that I get a 12v signal for the blue trailer wire (#5) at the trailer plug on the T'reg when the brakes are depressed. So the brake controller seems to be working OK.
The problem I have is that the black wire (#2) on the trailer plug isn't supplying power to the unit. Doing some research, this wire per Aus standards in the reversing wire.
Has anyone had to 'change' the black wire to a simple 12v power to run their trailer brakes? If so, where was the power sourced? There are 2 12V outlets at the rear right hand panel - could I steal one of those sources, or is there somewhere better such as the trailer control module?
The electronics diagram for the HBA-12 (see page 2 here--> http://www.hydrastar.com.au/LinkClick.aspx?fileticket=uQfi70bDVDE=&tabid=197) says I need 12V 25 / 40amps
