Hello,
This winter, I purchased aftermarket TPMS sensors from WheelWiz for my 2015 Treg with a new set of winter tires and rims, having taken off an original set of all-season rims with OEM TPMS sensors which were working fine when dismounted from the car. Unfortunately, despite multiple attempts to get the aftermarket sensors to work, including multiple trips to tire shops, VW dealer, reprogramming frequencies etc., the sensors never worked. VW did confirm to me at the time (this is now ~2 months ago) that the TPMS module itself was working and intact. I chalked it down to being an issue with aftermarket sensors and decided I would go with OEM for next season. During this winter season, the TPMS light remained on the dashboard. It blinks for about a minute or two after starting, then remains solid.
With spring coming around, I recently put on my OEM tires with original VW sensors expecting them to pick up automatically and for the issue to be fixed. Unfortunately, even after driving nearly 80km, the light remains on. I ran a scan as below. Please note, when I try to access module 65 it simply says "tire pressure controller no response."
Is there a way to activate this controller through VCDS? Is it possible this controller has incidentally died in the interim since VW took a look at it 2 months ago and now?
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 36 3C 42 46 52 53 55 56
5F 62 65 69 6C 6D 72 85 8B 8E
Mileage: 65061km-40427miles
01-Engine -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Cannot be reached 0100
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
Address 01: Engine (J623-CNRB) Labels:. 059-907-401-V2.clb
Part No SW: 7P1 907 401 C HW: 7P0 907 401 K
Component: 3.0TDI FSA H21 0010
Revision: 56H21--- CVN: AF4B74E538D3FF82755A21130E1FC39E
Coding: 292A4012237600050000
Shop #: WSC 07766 004 1048576
ASAM Dataset: EV_ECM30TDI0117P1907401C 001011
ROD: EV_ECM30TDI0117P1907401C.rod
VCID: 30391A4A8AAE614ABF3-8064
VINID: 9E65D48094A0A16500004147240BC0F655
No fault code found.
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J217) Labels: 0C8-927-7XX-V2.clb
Part No SW: 0C8 927 755 R HW: 0C8 927 755
Component: AL1000 AISIN 100 3374
CVN: E0C27B10
Coding: 010200000C008400000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_TCMAL991031 003118
ROD: EV_TCMAL991031_003.rod
VCID: 40D94A8A3A0EF1CA4F3-8014
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 R HW: 7P0 907 379 A
Component: MK25A H37 0521
Revision: -------- Serial number: 43304438108130 Dataset Number: 7P0012v____ 0001
Coding: 5B7613C349246F57DAF9C89A92DBF6607301
ASAM Dataset: EV_MK25AXT 010001
ROD: EV_ESPMK25A01000.rod
VCID: 4CC16EBA064625AAA3B-8018
Part No SW: 4H0 907 064 FK HW: 4H0 907 064 EK
Component: BCM2 2.0 H36 0560
Revision: 00002001
Coding: 0D860016000000000000
VCID: 77ABE1562FC076723E9-8022
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H40 0046
Serial number: 3214000159178016
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 CD HW: 7P6 907 040 CD
Component: Klima 2 Zonen H23 1406
Coding: B686000A80
VCID: 78A9E26A225E790A373-802C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DA HW: 4H0 907 063 AA
Component: BCM1 2.0 H20 0311
Revision: 22020001 Serial number: 00000960682902
Coding: 26000096D63C5D010020480300005D4C431C6608A2014261000000008040110000000000000000
VCID: 6A8DC8226C72DB9AB17-803E
Component: WWS 141110 033 0021
Serial number: 90243400141120224457
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20449566
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 AC HW: 7P6 941 431 AC
Component: E1 - LDS H02 0040
Serial number: 00000000002801160281
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 00000000095Z01D026DD
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 D HW: 7N0 919 475
Component: PARKHILFE 8K H06 0030
Revision: -------- Serial number: 28231433300295
Coding: 518D04
ASAM Dataset: EV_VW526ParkiAssis2 001013
ROD: EV_VW526ParkiAssis2.rod
VCID: 44D1469A2E16EDEA6BB-8010
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 561 C HW: 7P6 907 561
Component: ACC3 H21 0400
Serial number: 00000000000000
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContrVW526 002012
ROD: EV_AdaptCruisContrVW526_002.rod
VCID: 3C213E7A56E6952A13B-8068
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag04T H10 0043
Revision: -------- Serial number: 003NK001TYC- Dataset Number: 7P6003V____ 1643
Coding: 000000000000000000000000000000003454
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
VCID: 43D345862B18EAD2521-8016
Seat occupied recognition:
Serial number: 5850000R148200GX57
Serial number: 3575LRB404T2OJSOD9BV
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404T2OJSO0P8W
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3517ARB40692TNLU1OMK
Passenger side rear thorax airbag crash sensor:
Serial number: 3527ARB40692TNLU48E0
Serial number: 3557BRB405B2UUQ49PRR
Serial number: 3567BRB40612UFNAM0Q.
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 M HW: 7P6 953 507 AJ
Component: Lenks.Modul H06 0005
Revision: -------- Serial number: 01374NKL0007Y
Coding: 000CFD
VCID: 3D27337E4D7C9C22245-8068
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0071175 TRW 20141111
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 883 H HW: 7P6 920 883 H
Component: Kombi H13 0515
Revision: 13240300 Serial number: 658191114592065
Coding: 0B1733016F080008020004
ASAM Dataset: EV_KombiUDSRBVW526 001022
ROD: EV_KombiUDSRBVW526.rod
1 Fault Found:
16776973 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[RDK_01 keine Kommunikation]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:10
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 N HW: 7P6 907 530 G
Component: GW-CAN-L-FR-M H13 6042
Revision: -------- Serial number: 00000001659291 Dataset Number: 7P6067v____ 0041
Coding: 000103AD00
GVL: FB5F40651D7F680000
ASAM Dataset: EV_GatewVW526UDS 001007
ROD: EV_GatewUDS_VW52.rod
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 41323I50345701089639
1 Fault Found:
5707 - Tire Pressure Monitoring Module
U0127 00 [009] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:09
Voltage terminal 30: 11.8 V
Voltage terminal 15: 11.8 V
Control Module temperature: 28 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: OFF
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4H0 959 760 D HW: 4H0 959 760 D
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000125812753
Coding: 00581B0000004001000001010101202020202121202020
VCID: 3431165A7E365D6ADBB-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 7P6 907 566 A HW: 4H0 907 566 F
Component: SWA Master H06 0021
Serial number: 0353195296 Dataset Number: 7P6764V____ 0009
Coding: 030221
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VW51.rod
VCID: 3FDB497647F08E32369-806A
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 7P6 907 568 A HW: 4H0 907 568 F
Component: SWA Slave H06 0021
Serial number: 0352560029
Coding: 030221
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000127985165
Coding: 011D17205E00453005080001
VCID: 7AADF8621CD26B1A417-802E
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0354088444
Coding: 0187123A68B9509580A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 A HW: 7P6 959 719 A
Component: GTO BT H20 0059
Serial number: 21914563
Subsystem 2 - Part No: 1K0 951 605 C
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.062 H01 0008
Serial number: WOO3393223%
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.062 H01 0008
Serial number: WOO3414025-
Coding: 191100
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000128207274
Coding: 011D17205E00453005080000
VCID: 48C952AA12BEC98A873-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C14B1800935 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
VCID: 36352C5268CA4F7AE5F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0091
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0016
Coding: 012A02010B000400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_VW52.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0005
Coding: B00000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0005
Coding: B00000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H66 0133
Revision: AB001007 Serial number: 156L10E8121648
Coding: 020007020100000001
Shop #: WSC 27842 001 1048576
VCID: 2411E61ACED6CDEA4BB-8070
Part No SW: 7P6 035 664 G HW: 7P6 035 664 A
Component: H-BN-NA H40 0881
Revision: -------- Serial number: 273K10EB004367
Coding: 010200050040E9EF79022B0E00000003F00001030000000000
VCID: 3C213E7A5666952A13B-8068
Subsystem 1 - Part No: 8R0 060 884 CJ
Component: NAR 2015 1102
Subsystem 2 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Component: DU8 SV Touch H52 0046
Serial number: VWZ8Z9PX800213
Subsystem 3 - Part No SW: 7P6 919 603 L HW: 7P6 919 603 L
Subsystem 4 - Part No: 8R0 060 961 G
Component: CD-Database 5950
1 Fault Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Time Indication: 0
Date: 2023.03.26
Time: 18:09:13
Freeze Frame:
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000128594701
Coding: 011C17200000253005080000
Address 65: Tire Pressure
Cannot be reached
Address 69: Trailer (J345) Labels:| 4H0-907-383-V2.clb
Part No SW: 4H0 907 383 M HW: 4H0 907 383 K
Component: Anhaenger H14 0137
Revision: 7C001001 Serial number: 0350070537 Dataset Number: 7P0124v____ 0008
Coding: 0200000200000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW52.rod
VCID: 372B21566FC0B672FE9-8062
Address 6C: Back-up Cam. (J928) Labels:| 7P6-907-441-V1.clb
Part No SW: 7P6 907 441 G HW: 7P6 907 441 G
Component: TopView H08 0115
Revision: 11001001 Serial number: 82330JF0191160
Coding: 0100000000010000010102000000
ASAM Dataset: EV_CamerSysteTopViewVW 001014
ROD: EV_CamerSysteTopViewVW.rod
VCID: 3D27337E4DFC9C22245-8068
1 Fault Found:
9616922 - Supply Voltage for Front Surroundings Camera
B1284 14 [009] - Open or Short to Ground
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:09
Terminal 15 status: Terminal 15 on
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 339401590 Dataset Number: 7p0771v____ 0012
Coding: 0533310003
ASAM Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000128742048
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 7P6 907 217 B HW: 7P6 907 217
Component: DPC-SG H26 0035
Revision: -------- Serial number: 262130025421000 Dataset Number: 7P0EZ1v____ 0024
Coding: 69020000
ASAM Dataset: EV_OnBoardCamerDTR 001001
ROD: EV_OnBoardCamerDTR.rod
VCID: 392F276E59D4A00208D-806C
Slave 1:
Subsystem 1 - Part No: 7P6 907 658
Component: NICKRATENSENS H02 0001
Serial number: 000000007063583_3017
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 7P6 907 541 C HW: 7P6 907 541
Coding: 3701010101
ASAM Dataset: EV_AdaptCruisContr2VW526 002011
ROD: EV_AdaptCruisContr2VW526_002.rod
VCID: 3A2D38625CD2AB1A017-806E
Address 8E: Image Processing (J851) Labels:| 7P6-907-107.clb
Part No SW: 7P6 907 107 B HW: 7P6 907 107
Component: BV-SG H32 0035
Serial number: 005000011211147
Coding: 0AA118040000
ASAM Dataset: EV_BTR 002001
ROD: EV_BTR_002.rod
End----(Elapsed Time: 02:13, VBatt start/end: 11.6V/11.6V. VIgn 11.5V)-----
CVN: E0C27B10
Revision: 00002001
Coding: B686000A80
Coding: 004DBD
Coding: 025223
Coding: 518D04
Coding: 3701010101
Coding: 000CFD
1 Fault Found:
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:10
Coding: 000103AD00
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:09
Engine running: OFF
IN ZAS_Te_X: On
Datenfeld: 0
Coding: 030221
Coding: 030221
Coding: 191100
Coding: 191100
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Coding: B00000
Coding: B00000
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Time Indication: 0
Date: 2023.03.26
Time: 18:09:13
Freeze Frame:
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 29
Mileage: 65061 km
Date: 2023.03.26
Time: 18:09:09
Coding: 0533310003
Coding: 69020000
Slave 1:
Coding: 3701010101
ROD: EV_BTR_002.rod
