I have a 2007 Touareg V6 with 74,000 miles. It was purchased as a certified used vehicle in 2010, and the front brakes were new (replaced by selling dealer) at that time, 35,000 miles.
In June of this year at just over 70,000 miles I had the same dealer replace all brakes with what I'm told are OEM parts. When I got the vehicle back there was a vibration at 65-70 mph. This was diagnosed as a bent rim, but the dealer balanced the tires and indeed it helped the vibration problem. But the vibration came back, and a new vibration occurred under braking. In August I took the car back to the dealer and insisted on inspecting the bent rim. Long story short, we determined the rim is not bent but the tire was out-of-round. The brake vibration was addressed by resurfacing the front rotors (with only 2000 miles one them!). I had the tire replaced, and between the two services it helped for a while.
Now, both vibration issues have returned after only 2000 more miles. I'm taking the car back to the dealer tomorrow for another look. My question is whether or not this is a common problem among Touaregs of this vintage. If so, what is the recommended solution? Should I ask for a new set of front brakes? Is there any down side to resurfacing new rotors twice in the first 4,000 miles? Is there some other problem that is causing the warping, like maybe a bad wheel bearing?
The dealer has been very accommodating and apologetic. However, this is very inconvenient and I'm worried that these new brakes will not make it the 35,000 mile service life they seem to have.
