Afternoon Guys. My Touareg unfortunately blue it's Turbo the other day with failed turbo Shaft. I opted to try a cartridge replacement but before fitting the turbo to the car I wanted to test it's original actuator to confirm its serviceability. When the ignition is switched on you can see and hear the actuator cycling freely without any issues. Unfortunately during the VCDS output test if fails to operate even though the cycle % fluctuates shows test complete and then throws up the electrical malfunction J724 P3348 message. Is it likely that the actuator is toast or am I missing something? Any help would be appreciated 👍
