Anyone experience tire wear issues with having higher than recommend tire pressure. I know that you can have issues if you are low, but did not expect that if the pressure was a bit high. Here are the details. I have about 3,000 miles on brand new Kuhmo STX 285/45/19 tires. They were quiet when purchased, but now the front tires sound like a monster truck. I have noted uneven wear between the section of rubber with one higher than the other. This is certainly contributing to the noise level. I got them installed at a local VW/Audit independant shop after researching the tires and finding good reviews. They apparently put about 49 psi in both the front and rear. I never thought to check until I checked them due to the noise and the wear. Our truck is never loaded heavy, so today I set the front to 40 psi and the rear to 45psi. That is in between the recommended pressure for light and heavy load. Unfortunately, the damage is done.
One more thing, the previous tires were Continental and were wearing perfectly and they were very quiet. I can't remember the model. I don't think I was able to find the exact model, but was looking at Michelins.
So, the questions.
1. Can over pressure (49 psi in this case) contribute to this odd wear pattern? Keep in mind that this is only 3K miles of easy city driving.
2. Should I try to get them replaced on the warranty since there is an uneven wear warranty (no treadwear warranty), or maybe try them in the back and set all to correct pressure?
3. Realize that I threw away $800 on cheap tires and buy some better ones (not a option I want to think about).
So, the questions.
