Hello all,
Apologies if this is posted somewhere else but I am very, very bad at using the search function o the forum.
My VW came with 275/45R20 with a set of 50$ street tires. I am looking to change to a set of 19" rims (or 18 if I can find any) and a set of tires with 55 profile (aspect ratio) or 60 if I can get 18" rims.
Using the scenario of 19" rims and a 55 tires:
Online calculators tell me that my current setup has an overall diameter of 756 mm and the new setup will have 774 mm (2.5% increase)
I went to my local tires shop and the guy had a small meltdown and said that this will make my car give a lot of error codes because the change in diameter will change the speed reading on the speed sensor.
I am not a specialist so I did not argue but I do remember that modern cars use the ABS sensors for speed detection and that as long as all your tires are the same size there would be no issues and the speed will show exactly the same. Is he correct? And if he is then can the sensors be recalibrated in any way to compensate?
