Tail Lights and My dealer holding me hostage!
9K views 27 replies 11 participants last post by  GloucesterVWGuy
All,
I called my dealer yesterday and asked them how many $'s it would cost me to have them replace the tail light bulb (brake light) on my Veewee, they told me that it would be 110.00 $, I told them that there was a TSB out on this light assembly and that if the white plastic retaining clip were to be replaced per the TSB then I could replace the light bulbs at will or when they blow out... Ahh Sorry sir but there is no TSB for your Vee Wee, if you want the bulb replaced then its 90$'s and hour plus tax and bulb.
I went home and took a look at the light assy and found out how to remove the assy without breaking it.
This is how
I'm working on the passenger lens
Grab a 1 beer
a torx bit screw driver or a small flat screw driver
a thin sturdy piece of plastic (I used a bike tire pry bar, I use them to replace my clincher tires on my road bike tires) or a very small flat screw driver.
one osram bulb from your dealer, these bulbs look like 1157 bulbs but the mounting tongs are off set a bit.
First take the small flat screw driver an pop off the plastic caps that cover the two bolts, these two caps are located to the left of the lens, the rear door needs to be open, once off you'll see two screws, use the torx bit driver or a flat screw drover to remove them.
Now the hard part, by the way I sat looking at the darn thing for a half hour, looking behind it around it pulling on it gently, to no avail it still would not come out, what ever you do don't force it. The stud and the white plastic mount are located on the right bottom corner, this would be nearest the rear right tire.
Anyhow, this is how I removed the lens.
Tip the top of the lens out towards you and take your small plastic pry bar or small screw driver and slip it behind the lens between the PAINT and the lens position it as low as you can on the right bottom corner of the lens, don't force the prying tool or you'll screw up the paint, now pry gently the pry tool so that the tip of the tool (the tip should be 2 cm inside the space so as not to mess the paint) touches the paint and the edge of the tool touches the edge of the lens, now grab the lens with you right hand and pull the lens toward you and pry gently teh lens gently towards you with your left hand, barely no pulling force is needed and pop it goes!
Once you have it off the then remove the bulbs from the back of the assembly!
Dont forget to grease (lithium grease) the silly mounts or take it to the dealer and tell them to fix the damn thing! The grease allows you to pull them off even if you have the white mounts.
Now the my rear lights come off without a problem!
JD
2004 Volkswagen Touareg
Bulletin #: 0303
Sequence #: 10003932
Date: 08/05/2004
Component Name: 123000 exterior lighting:tail lights
Make: Volkswagen
Model: Touareg
Year: 2004
Summary: Tail light assembly, removal procedure. *tt this bulletin replaces 0303 dated 09/30/2003. *tt
jdunn54 said:
All,
This is how
Grab a 1 beer
First take the small flat screw driver an pop off the plastic caps that cover the two bolts, these two caps are located to the left of the lens, the rear door needs to be open, once off you'll see two screws, use the torx bit driver or a flat screw driver to remove them.
Tip the top of the lens out towards you and take your small plastic pry bar or small screw driver and slip it behind the lens between the PAINT and the lens position it as low as you can on the right bottom corner of the lens, don't force the prying tool or you'll screw up the paint, now pry gently the pry tool so that the tip of the tool (the tip should be 2 cm inside the space so as not to mess the paint) touches the paint and the edge of the tool touches the edge of the lens, now grab the lens with your left hand and pull the lens toward you and pry gently the lens gently towards you with your right hand, barely no pulling force is needed; and pop it goes!
JD
Bulletin #: 0303
Date: 08/05/2004
Make: Volkswagen
Model: Touareg
Year: 2004
jdunn54 said:
The removal of a brake light should never require special tools that can are only readily available for machanics.
Mine brake light has just gone this evening, I was wondering how to do it and the dealer said its possible the lense may crack and this wont be our fault, I just left the dealer, its not my normal dealership, which I will head over to tomorrow.
Both my rear brake lights just went out on my way home from work. I've had a number of vehicles over the past 20 years and never had this happen before. I am glad to have found this post. I stopped and got two replacement bulbs already, do not know the brand. I am going to give it a try and hope this doesn't turn into one of those "shoulda' gone to the dealer" moments. Thanks for the info!
Stolen from the above thread. Pictures!
And here iPhone pictures of the speed nuts I just picked up from the stealership:
Yes, although I wouldn't exactly call it a speed nut since it has no threads. it is the white socket the silver post on the back of the tail light pushes into. The white socket sits in a hole in a bracket that is part of the body work
I need to get a new one since I broke the one there when I pulled the tail light housing out to change the bulb so I need to know what it is called or some kind of part number so I can order one
thanks for your quick reply
The replacement plastic sockets are black and should be installed in place of the white one. Even replace the white one that was not broke. There was a tsb out that the white ones are to be discarded.
I once had to buy a hubcap (remember those covers for the steel wheels)
Parts dept and myself both could not find it.
It was listed as "wheel hub assembly."
Thanks for the help part is ordered!
Next thing I have to tackle is replacing the gas struts that hold up the rear hatch. Went to the car show in LA after thanksgiving and noticed they moved the struts to the outside on the new Touaregs much easier to access. It looks like I have to disassemble the entire interior to replace the struts on the '07
There is a good how to thread on here.
Search for the key word luber. This is a critical piece of equipment you need and is unique to the rear hatch strut replacement how to.
They are so cheap why aren't you just getting them from your local dealer?
My dealers [different marques] kindly post small stuff to me, usually without charge. Chat up the parts guy when you're there and also get them to run off the build sheets for your car.
well I returned home this evening pulled the turn signal bulb Philips PY21W, it didn't look like it was damaged but I replaced it anyway, unfortunately the Touareg still thinks it is out. I tested the bulb with a 12 volt supply and both the original and the replacement light up. The right blinker still runs fast and the warning still comes up on the dash. Left blinker works fine, on the right the light on the right side mirror works - but not the right rear. Any ideas? I tried searching the site but I am probably not using the correct search terms
thanks
My mistake the front passenger side turn signal is also not working, so after a little searching I see someone mention it could be a fuse. I'm surprised that there are separate fuses for the front and left side turn signals
I pulled the cover off the fuse box but can't figure out the pictogram so more research to be done
