Those of you TDI owners may be well aware that every 40k you need to replace the fuel filter. The stealership wanted 400 dollars plus 150 for the oil change; totaling 650 bucks for the 40k service. Below is a link on replacing the fuel filter on a tdi passat. the set up is identical on 2012 forward Touaregs (not sure about the 2011's).
So just some minor differences. Ours is towards the back and not as close to the front of the compartment. I pretty much did exactly what he did but I did not suck out all of the fuel in the compartment. I just took the filter out. Then dipped the new filter into diesel fuel first to make sure it soaks it up (BE VERY CAREFUL NOT TO GET ANY FUEL IN THE TOP HOLE OF THE FILTER BECAUSE THAT IS THE CLEAN SIDE).
Also, I did take some fuel out and slowly put the new filter in. If it looked like it was going to spill over the top of the filter i pulled it out and took some fuel out. If it looked like it could handle a little extra fuel, I added some. Put a little diesel fuel on your fingers and moisturize the blue seals on the new filter. This will help ensure it seals properly.
I did not have a small enough torque wrench. I am a firm believer in torqueing to the right specs so that the proper pressure is applied to the seals. If you are not tight enough it could leak, if you are too tight it could potentially leak by pinching the rubber seal too much. As I said, I did not have one so I took a little risk and tightened them firmly. Be sure to tighten evenly and across from one another just as you would if you were putting on a wheel.
This is key. With this new set up, there really is no need to use a vagcom to prime. If you make sure there is enough fuel in the container and if you make sure you presoaked your filter first, it should fire right up. I did as an extra precaution, push the start button without hitting the brake and then did the same thing to turn it back off. I did this like 3 times without actually turning over the car. Then I did start the car as I normally would and it fired right up. I would say it turned over a half a second to a full second longer than normal. Barely noticeable. I then drove it around for a few minutes to make sure it was was good to go. I think i saw a power improvement and better throttle response.
Some last few tidbits. Before removing the top on the fuel filter canister, make sure you clean the area so that no particles fall in. Second tie back the canister top with a zip tie to make it easier for you to work. You do not want the nipple of the top to get any dirt on it.
In the end this cost me 60 instead of 400 bucks. I still had them do my oil change because I do not see much of a benefit in doing that myself. To much work and mess for very little savings.
BTW- at the oil change, I was quoted 160. I thought that included filling my adblue tank. They called me and said my adblue was low (no crap there was a warning on my dash). They wanted 89 dollars to fill it. Seriously the VW fluid costs 16 bucks. I plan to do that myself as well. Just buy the small bottle first since it has the attachment. Then cut the bottom off and pour the bigger bottle into that whenever you want to fill it (almost like a funnel). I prefer to use the VW small bottle to fill it because it protects you against over filling and spilling over, which could cause other issues.
Hope this helps any other adventurous people who like to save money and try to do some of the easier things on their own.
