Hi there, I have previously upgrade my 08 T2 with a genuine RNS2 DVD nav unit, wife wanted original after issues with aftermarket head unit in Merc ML.
All works fine and even the outdated maps are not a problem for her, now I've moved on to a reverse camera retrofit. I've picked up the module, 7L6907441C and wiring harness 7L6971148AE. I know I need the mounting bracket and vag codes but is there anything else I need?
I've had a look in the rear quarter compartment and cannot see any correct size plug for the module, also the rear door harness I purchased has the grey video plug next to the blue main connector but they mount in the rear roof section. I'm assuming there may be more wiring harness needed?
Is there any connections needed to plug into the head unit?
I'd appreciate any help or advice from anyone who has undertaken this retrofit.
Steve
Steve
