1 - 2 of 2 Posts
KraftwerkTurbo
Discussion starter · #1 ·
I have driven a few Cayenne (not GTS, but Turbo) and found they are the best handling full size SUV of that generation.
I like my Treg (with air suspension), but would like to improve the handling. Since Cayenne and Treg are build on the same platform, I would like to swap sway bars from a Cayenne into my Treg.
What donor car (year/make/model) of the Cayenne is a good fit?
What swaybars is the GTS using, what is the Turbo using?
What parts do I need to swap (mounts, bushings (upgrade to aftermarket, PU?, links, etc)? Part numbers?
Both recommended? Or start with front?
Who has swapped Cayenne sway bars into the Treg? What was the effect?
Reactions: dapinitial
Have you done the lower sway bar modification yet?
I also feel the same way I’ve upgraded my lower and upper control arms use poly bushings wrapped with plumbers tape and greased properly and it’s quiet and feels better. It’s not perfect… feels Floaty to me…
I also like the Cayenne handling as I prefer the stiffness of my 2006 audi S4… I have air suspension and everything works great. My tires are oversized, which I’m sure doesn’t help. My CV axels are good… Considering doing my tire rods. Maybe adding a strut bar?
1 - 2 of 2 Posts
