Hi guys. I would like to start a thread for some technical information on the suspension, springs, and dampers.
For example technical specifications of springs, and the struts (dampers).
I will begin with the limited information I have.
Front suspension
OEM Struts 125mm stroke
Max stroke strut that will work without modifications 155mm according to me. 159mm according to a company I don't want to name.
From EUROWISE - Below ones require mods / body lift.
JRZ short struts 165.1mm
JRZ struts 177.8mm
Bilstein 216mm
Springs
I'm still chasing actual OEM spring rate numbers.
But most after market (offroad style) struts seem to use 650lb/in on the front and the back.
If there is more information or if someone wants to take this information and put it in a proper format that would be great. We need a sticky with proper technical suspension information. I could not find any on here.
Luke.
Front suspension
JRZ struts 177.8mm
Bilstein 216mm
Springs
- 7L6 411 105 M
- Outer diameter [mm] :120
- Length [mm] :433
- Diameter [mm] :15
- 7L6 511 115 K
- Outer diameter [mm] :119
- Length [mm] :418
- Diameter [mm] :14
- 7L6 511 115 F
- Outer diameter [mm] :118
- Length [mm] :405
- Diameter [mm] :13,75
Luke.
