Starting problem vw touareg
36K views 33 replies 15 participants last post by  Scorror
Hi! I have a problem with my touareg, whenever it stands for a while it wont start whitout problem!
Sometimes it makes loud kracking noise, like the flywheel is not joining with starter and after that it just
klicks until it finaly starts!
When i'm driving around it doesn't make any problem only as said when it stands for an hour or more!
I have already put in new starter(twice), new batery , it was a rellay replaced that was using up power suply!The
flywheel was checked and is ok!
I have this problem since august last year and nobody sims to know what the false could be?
I would be very greatful when someone could help me on this or have some opinion! Thanks
Check starter wire at positive terminal in battery box for connection/damage to wire
I tried to upload a sound record but its not going.I just dont understand how a mechanic cant find the problem.We had it on computer four times but it showes nothing special.Just a code P00455 for a leak and the code P00446.But when we started the engine again all codes were gone.Today at the morning the engine started with no problems like its all ok.But after few hours it made again the loud noice like the starter stucking somewhere at than it make nothing at all when i am turning the key like he is not getting any power.After a few times of trying he started again.its just make me crazy i alredy spend a 1000 € on it.
I have an apointment at vw servis.They will check it with the computer but i dont think they will find something i didnt heard allready.Someone sad it is the flywheel and something in the steerig wheel that cost 2000€.I dont know.I dont belive.Seems like my car cant be fixed.Not in Slowenia :(
The battery meter on the dashboard should read just over 14 volts when the engine is running. The Touareg is very sensitive to low voltage and anything less than 14V can throw up faults.
I had a similar problem with my 2013 Touareg TDI. Sometimes it would start, other times not. Also a lot of noise sometimes.
I took the car to the VW service after I charged the battery, and then removed the battery and took it to AutoZone who tested it twice saying it was OK.
The VW dealer said the battery was OK. Problem: Bad armature in the starter. The starter was replaced and the problem was resolved.
Good luck!
I got a real left field idea that it could be.
This is an idea only.
Crank position sensor. Seems like the engine goes to start and then the ecu freaks out coz it has no idea what poition its in TDC or BDC etc.
But this is a lil ways off. Got a feeling its not the battery. Maybe starter but its very weird.
God it doesnt sound healthy on start up.
Waiting eagerly on the results of the shop!
Update us already!
