Please excuse my noob-ness, I am a longtime lurker who finally pulled the trigger on an '06 V10 about six months ago. While my short time as a Touareg owner has been frustrating at times (a $200 service tool to change the oil filter?) overall I am pleased with my purchase.
I have an issue though that I cannot seem to solve. My girlfriend left the interior light on in our Touareg and now the starter will not engage/crank. I tried jumper cables, no luck. Hooked up a battery charger to the terminals under the hood, no luck. I put a voltmeter on the rear/starting battery and it was reading 12.8 volts. Then I checked the front battery under the seat and it was only 10.7 volts. I pulled them both out, filled the water (these appear to be replacement batteries from CarQuest), and trickle charged them overnight. After reinstalling the batteries, still no luck.
I did some searching on here and do not seem to have the same symptoms that others have had. The key fob still works, I can hear the steering column lock releasing when the key is put in the ignition.
Am I missing something simple here? I hope so! The vehicle has 110k miles on it and is out of warranty.
