I had a problem with a Transmission Error message, and later, I check engine warning light. I detected no change in performance.
on my second try to fix, the dealer found the fuel pressure to be lower than spec. They replaced parts and told me it was the cause of both the transmission error and check engine. Did not seem to make sense that was the cause of both warnings.
it was. Issue solved.
