Hello all, 2012 V6 TDI CATA, Darkside cat/dpf/egr/scr/def delete, Malone stage 2 tune.
What im currently experiencing is heavy smoke on start up smelling of fuel, i've heard that a little bit is normal with the deletes and tune but this is excessive for sure. VCDS is telling me my cylinder 6 deviation on cold start is 1.2 mg/stroke but this drops down inline with other cylinders in the .6 mg/stroke range as the engine warms up, I replaced the injector and put in the new callibration code but am getting the same thing. I did not check this before doing the deletes and tune as there was no sign of anything wrong and I have a feeling the cats and dpf may have been covering it up. The other option is that perhaps I got a bunk tune and this is some kind of warm up procedure to speed up the emissions systems heating up.
I also checked today for blow by out of cursiosity, im not very familiar with tdi's so I dont know if this is a normal amount or excessive, this was on a cold engine so the steam is to be expected.
Thank you.
Thank you.
