1 - 5 of 5 Posts
Check all 4 height sensor linkage rods at each corner. The ball joints can rust/seize and eventually break. The fronts are very easy to spot through the wheel well.
If it has been 2+ years since you replaced your battery, just do that first to avoid spending $$$ on unnecessary parts.
another genius, well thought out parts cannon.
This account has to be some form of bad AI.
It won't affect smog.
For the running gear fault, I'd suspect vehicle battery first, then mechanical issues. If it has been 2+ years since you replaced your battery, just do that first to avoid spending $$$ on unnecessary parts.
Or, you can actually do some testing, including get the battery tested to avoid having to spend $$$ on unnecessary parts or batteries.
1 - 5 of 5 Posts
