Removal of interior door panel (Driver door)
30K views 10 replies 8 participants last post by  Paulineother1
Hi Folks
Has anyone removed the interior driver door panel. I have a very bad rattle from behind the panel. There are two screws at the bottom of the panel are there any others or just clips? does it hang from the top?
many thanks
Lorcan said:
Hi Folks
many thanks
There are two more screws behind the plastic cover which is behind the armrest handle. The rest are just clips. Be very careful when releasing the clips or the panel may crack and is pretty expensive to replace. It does hang from the top when all of the clips/screws are undone.
hI EVERYONE,
I am a new member and would like to ask were the air compresor is located to inlate spare tire? User manual translation (From German to Spanish) are terrible and can't understan were should be located.
2006 V6 3.2 Touareg
Thanks,
On the V8 T2s the connection is below the passenger front seat. On the V6 it should be in the compartment where the collapsible tire is located.
Check on e-Bay for copies of manuals etc or buy a version of Bentley or Elsa.
siberian
The connection to fill the tire will be under the passenger seat only if you have air suspension. It is not a motor specific item. If you don't have air suspension then you should have a little black box beside the spare in the rear.
I have an 04 passenger side power window stoped working I can hear noises when I press the button so I know motor should b good but I'm afraid of trying to take door panel out does anyone have pics where the clips and screws are and intructions of how to take it out thanks guys
Nice!
Only the four screws but they are Torx 21 and 25.
Longer the shaft on the Torx driver the better.
Just as stated above. 2 under panel. 2 behind handle cover plate.
Unclip at bottom and lift as its hooked over window slot :)
Just changed my mirror. No sweat!
