I have an '04 V8 with 165,000 miles. Is it possible to disconnect the front drive shaft and the two front prop shafts and make the vehicle rear wheel drive only without breaking a seal or screwing up the computer?
Nope... Quick check reveals 41 different front diffs used accross the range. Two different connecting flange sizes and at least 8 different ratio's. At least 8 of the 41 were used on the V8.I think they're all the same for v6/v8/v10, there's no locker option or different ratios. I'm sure someone else can confirm.
