Hi guys, having finally got my VCDS, I'm going to finally try to fix my issue.
As a little background info (cry for help!), car is 7L 107K miles, and was fine until the alarm went off one morning, so I got out of bed and opened the car having pressed my key fob. On closing the door, the right front air strut released all its air and the front end has been on the floor ever since.
I did notice before this incident the vehicle was losing height overnight across the front axle, and generally lower to the right hand front corner.
The rear is stuck in XTRA Height and will not drop, whilst the front will, albeit slowly, raise to offload height, but there is imbalance between the two.
Seems to be a component failure.....the pump runs, the front end raises, the back end is stuck?
Any input / advice would be gratefully appreciated.
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L6 907 553 B
Component: LUFTFDR.-CDC- 3C1P1 3650
Coding: 0025520
Shop #: WSC 00201 219 06748
VCID: 382921217E4ACFBB773-5160
1 Fault Found:
01400 - Suspension Level Control
001 - Upper Limit Exceeded - Intermittent
Coding: 0025520
1 Fault Found:
