Dear All,
I had the dreaded transmission tunnel vibration so did the 8 bits if 18mm OD hose repair where the support rubber for centre bearing had disintegrated.
After 5,000 miles no sign of any wear but put in a ÂŁ30 ebay bearing just in case.
This is how it went, I have car lift but not much skill, Hardest part was removing axle end CV joint, managed to get drift though threaded end of axle flange but it took a lot of thrashing!
Alignment mark centre CV and dismantle, alignment mark splines in CV to shaft, make certain these are not removed when you pull boot on or off!
centre CV removed from splines by very gentle hand pullers and then opening up spring clip with screw driver, this looked impossible but was easy.
Bearing tapped on and off without problem.
NB bolts for doughnut are two different lengths.
The repair by hose kink would probably have lasted the car out but I can now know prop shaft is good for another 50,000 mile.
So about ÂŁ30 and 3 to 4 amateur hours and I do not get someone else's scabby prop shaft.
