21 - 26 of 26 Posts
Discussion starter · #21 ·
Not such a good 'howto', I made a mistake. Since mine sort of exploded I had to refit the front slider covers. If you take off the rear covers before you tilt the seat you're done.
Anyway, happy Treg this morning, fired up right away.
Discussion starter · #23 ·
Oh dear...checked the rear battery today, it's still the OEM one. :confused2: Tested it... pretty weak. New one on the way. Madly expensive. :mad:
Oh for those who wonder:
Front battery is Varta I1
Rear batery is Varta G14 AGM
Ok, time to update this thread. I put the old battery for 24h on my little 5 Amp charger and it took the charge, it was at 8 Volts when it came out, now showing 12.6V on the digital tester. Then I used my load toaster, it showed normal, dropped only to 11.5V on full load (and then the tester got seriously hot, I pulled the trigger for at least 30 seconds). However, since this is such a big battery (110Ah) that was misleading.
Testing it with an acid tester: 1 as good as dead cell and the other 5 holding minimal charge. Never seen that before, a battery in bad condition and still that much power. So I dropped in a new Varta I1 today and...mini heart attack. Turn key:nothing. :confused2:
Took up to a minute or so before the I got a response and the the MFI came alive. Treg was 'starting windows' I guess. Did an AMP test, tester doesn't even move with car in sleep mode so no power drain. Engine on, volts on dash jumps right away to 14V while before that was 13 and a little bit V. Amazing how sensitive this little gadget is, well done VW. Load test on battery:14.2V.
Radio flashes 'safe mode - enter code' screen for 3 seconds and then turns on my favorite radio station, so you guys were right, no need for back up power when you unplug the battery.
Then....the plastic upholstery around the seat sliders...is that German humor? The DIY should be updated for the T1, do not tilt your seat while you still have the plastics in place, the rear ends will snap off and that is not funny. To get this crap back in place is no walk in the park either. They are held with some metal clips that only work if you slide in the plastics, they do not 'click on'.
Tip: if you have a dead utility battery, put some jumper cables on your Treg so you can move the drivers seat. Put it in the utmost upper position otherwise you almost cannot get the big lower front cover off without braking something. Then move it all the way forward and (from the back seat) remove the rear short slider covers. Just pull them towards you and they will come right off. Then put the seat in the utmost rearward position and pull the front slider covers. Look closely how they are fitted.
I found 4 eurocents and 3 business cards in the void between the central console and the seat..yay :eek:
I also had look at the Coolant pump error, relay checks out fine, swapped it with the fuel cooler relay, still same error coming back on OBD. Darn..so it's not the relay. Will test more this weekend....
I had the same problem- found out the following (2003 V10):
when I pulled the relay out of the socket I looked at the cable connection coming up to the groundplate (where the relay sticked in). The cable was not fully engaged but had a some millimeters wide gap to the relay socket- so probably no connection... Avoiding to dismount the whole groundplate (with disconnection procedure of batteries and so on) I simply prolonged the relay contact with a small piece of copper and plugged it back in- works until today- error messages are gone
br
Mark
Yes no problem with removing battery
Hello,
As ppl have stated there is no need to get the code, the unit uses an eprom and is coded to the vehicle, so although it may come up "code needed" briefly it will sort it self out within a few seconds guaranteed (as long as its original to vehicle).
Warm Regards
Mark
T1 V10
21 - 26 of 26 Posts
