2004 V8 US model
What are the most likely suspects?
New VW Gas Cap
Small vacuum hoses under hood look good. No cracks and tight fit on all ends I can easily get to.
Has not had VW Gas Tank Recall done, but did get new fuel pumps a couple of years back.
(I didn't do them, so can't say how good a job sealing the system)
I have read a lot about the N80 purge valve on other Audi/VW systems. Is this the valve at the back-top on the left side of the intake?
If so, can I run known good a hose from it to a generic vacuum canister as a test? (Are there sensors or valves in the vacuum canisters that I need to be concerned with?
Can I close off the vacuum line running back to the tank as a test?
Where does it measure the tank vacuum to trip the error?
I have also on occasion received a P0442/16826 code. (This was the code with the old gas cap)
Does this help track down the problem.
New VW Gas Cap
