Hi folks ,
From the title this might seem like another issue where someone says ....do a search .
Believe me i have ....for months.
We have two Tregs ... Mine is a 2008 2.5 Diesel ... My daughter has a 2007 3ltr V6 .
Both are in great condition ... treated like spoiled children and given the best of oil , filters and regularly serviced.
For a while now ...both have been having the yellow oil can warning ( low oil level ) on the dash.
Neither have any oil loss ... on level ground they both have the correct oil level.
We have changed the oil level sensors , the oil pressure sensors and although it sounded silly .. the hood latch and switch.
I have checked both with VCDS .. neither shows any codes .
If I open the hood with the ignition on ...wait 30 seconds ... close it again ... and then start the engine the light will go away for sometimes a week ...sometimes a day or so.
I'm pretty much out of ideas here ...
Since it seems to be a common issue right across the VW product range ( I have been searching a lot ) ... I can only guess that it might be some sort of ecu based software glitch that throws a false warning .
Does anyone have any ideas....or know a way to disable the sensor via VCDS . its not needed anyway as I always and regularly check oil levels with the dip stick ..rather than relying on a sensor on the dash ..
Please help ...at my wits end here .. 😧
