Just partially installed hitch kit part # 7L0-092-105-UA on my 08 when I ran into a little issue. The problem is the bolt holes in the hitch are too large allowing me to position the hitch +- half an inch up, down, left or right. The original bumper had smaller holes allowing the bolts to self-center the bumber assembly. Looks like the holes need to be sleeved down to accept the M12 x 1.5 bolts my vehicle requires.
Searched around a bit to see if I could find a solution and noticed that 1stvwparts.com includes "adapter sleeves" in it's hitch kit. Does anyone know if these adapters are designed to sleeve each hole so the M12 bolts will fit properly?
Thanks you.
-Randy
Thanks you.
-Randy
