Wondering if anyone has come across this problem. I have a 2013 Touareg TDI with 42K miles. Came back from a trip and realized interior light was one for 10 days. Car was a little slow to start. Charged battery at 2amp rate for 20+ hours. Car would start and run fine, but from time to time would not start, would buck and be all rough. I'd turn the key off and it would start. Other time it would try to start, and not, but the dash would flash and nothing.
I charged the battery last night, 20amp rate for 3 hours. Checked the battery with a volt meter this morning and it was 12.37 volts, 12.26 under load (headlamps).
Car started several times and suddenly not. I hooked up my OBD2 and received a code U0401. It seems this is the Body Control Module? Has anyone heard of this issue? Is this easy to replace? Location?
Any help is appreciated.
Just looked up the code of CanOBD2.com The response was "Invalid Data Received From ECM/PCM".
Clues?
Clues?
