Transporting a queen-size mattress can be tricky, especially for a 70-mile trip mostly on the highway. I’ve had to do this myself, and I found a few tips that might help you out. With the stock roof rails on your T3 and some good-quality ratchet straps, you can definitely make it work, but you’ll need to take some precautions.
First, make sure your mattress is securely wrapped in a mattress bag or plastic sheeting to protect it from dirt and weather. Then, place the mattress flat on the roof rails. Using at least four ratchet straps, secure the mattress tightly. Make sure to strap it down at multiple points: two straps across the width and two along the length. This will prevent the mattress from moving or catching the wind, which can be dangerous at high speeds.
When I transported my mattress, I made sure to check the straps periodically during the trip to ensure they stayed tight. Also, drive a bit slower than usual and avoid sudden maneuvers. It's definitely doable if you take your time and secure everything properly.
I found the blog on Sleep Advisory really helpful for more detailed tips on transporting mattresses. It provides a step-by-step guide that might give you more confidence in using your T3 for the move.
Using a pickup truck is the safer and more straightforward option, but with careful preparation, you should be able to transport your mattress safely on your T3. Good luck!
