I have a few faults in this scan but it's the P0266 that's causing the check engine light to come on.
Saturday,22,April,2023,16:18:21:45860
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.0.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230228 DS346.1
www.Ross-Tech.com
Mileage: 208237km-129392mi Repair Order:
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
69 6D 72
VIN: WVGFK9BP1CD003632 Mileage: 208237km-129392miles
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CATA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI FSA H17 0008
Revision: 56H17--- CVN: 66FD960038D3FF825C3E0D04
Coding: 292A4012233600050000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
ROD: EV_ECM30TDI0117P0907401J_002.rod
VCID: 36352F9438CC4FFAE5F-8062
VINID: 9E65D66C94A00535000031830891DD5440
2 Faults Found:
4927 - Fuel Injector #2 (N31)
P0266 00 [232] - Contribution/Balance Fault
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 208010 km
Date: 2023.04.17
Time: 18:40:21
Engine RPM: 1313.50 /min
Normed load value: 0.0 %
Vehicle speed: 54 km/h
Coolant temperature: 87 °C
Intake air temperature: 29 °C
Ambient air pressure: 830 mbar
Voltage terminal 30: 14.220 V
Unlearning counter according OBD: 40
Pressure control valve adaptation factor: 1.0538
Injector 2: rail pressure calibration point 1: 102.10 µs
Injector 2: rail pressure calibration point 2: 8.00 µs
Injector 2: rail pressure calibration point 3: 5.60 µs
selected gear-Bits 0-7: 6
Actual charge pressure: 831 hPa
5604 - Park/Neutral Switch Input Circuit
P0850 00 [032] - Open or Short to Plus
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 206163 km
Date: 2023.04.04
Time: 13:21:39
Engine RPM: 830.50 /min
Normed load value: 23.5 %
Vehicle speed: 0 km/h
Coolant temperature: 92 °C
Intake air temperature: 41 °C
Ambient air pressure: 840 mbar
Voltage terminal 30: 11.940 V
Unlearning counter according OBD: 16
Accelerator pedal travel: 0.00 %
Accelerator pedal: sensor voltage 1: 742.6 mV
Accelerator pedal: sensor voltage 2: 371.2 mV
Accelerator pedal: switch positions-Bits 0-7: 72
Starter control: Interlock- or P/N-signal-Bits 0-7: 1
Limitation: torque: 191.0 Nm
Control Module temperature: 31.2 °C
Readiness: 1 1 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 3407
Serial number: CVN: CB5A7D50
Coding: 001368
Shop #: WSC 50658 003 1048576
ASAM Dataset: EV_TCMAL991031 002112
ROD: EV_TCMAL991031_002_VW52.rod
VCID: 3039198CDAA861CABF3-8064
No fault code found.
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 422710010EC010 Dataset Number: 7P0012v____ 7P13
Coding: 5B7613C349242556DAFAC89692D4A4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 45D75858752AD4627C5-8010
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 09860000000000000000
VCID: 73B3D6806BBE1AD2021-8026
Subsystem 1 - Part No SW: 7P6 959 754 AM HW: 7P6 959 754 AM
Component: FBSTOUAREGIDG H08 0084
Serial number: 3617000028236001
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000157198015
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: B606200880
VCID: 74B1D59C6E301DEA1BB-8020
1 Fault Found:
0243 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 41
Reset counter: 84
Mileage: 205102 km
Date: 2023.02.15
Time: 08:24:41
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001035544
Coding: 26009017D03CFD010020100300005D0C431C660882010261000000020000
VCID: 6B83CEE0338EC212CA1-803E
Component: WWS 110728 31 0020
Serial number: 90243400110830033014
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Serial number: 10225946
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Serial number: 00000000002408110261
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Serial number: 0000001805569R0SXR07
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261124100652
Coding: 110501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 42DD43446404E35A597-8016
1 Fault Found:
1112324 - Front Right Center Parking Aid Sensor
B10F9 04 [008] - Internal System Fault
Freeze Frame:
Fault Priority: 3
Fault Frequency: 35
Reset counter: 94
Mileage: 205081 km
Date: 2023.02.13
Time: 10:00:14
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag025 H05 0023
Revision: -------- Serial number: 003JX003XKZH Dataset Number: 7P6003v____ 0785
Coding: 000000000000000000000000000000003235
ASAM Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 40D9494C6A08F14A4F3-8014
Seat occupied recognition:
Serial number: 5850000R1160104N9V
Serial number: 3575LRB405N0NI3629II
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585LRB404R0OPI27HKD
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515RRB404V0M5SQ28PJ
Passenger side rear thorax airbag crash sensor:
Serial number: 3525RRB405R0M98EAOC0
Serial number: 3555NRB404P0M8GEF0T1
Serial number: 3565NRB40690N49O38LJ
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KI20003N
Coding: 000015
VCID: 36352F94384C4FFAE5F-8062
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0108747
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658070911592021
Coding: 836F33022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47CB52504F26C6728E9-8012
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000237609
Coding: 0001037500
GVL: FB4F40051D7B000000
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 382921AC32D8B98AF73-806C
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650254975
2 Faults Found:
12290 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 81
Reset counter: 94
Mileage: 205094 km
Date: 2023.02.13
Time: 15:23:53
Voltage terminal 30: 12.5 V
Voltage terminal 15: 0.0 V
Control Module temperature: 17 °C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
[Powermanagement active]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 45
Reset counter: 94
Mileage: 205102 km
Date: 2023.02.13
Time: 22:37:50
Voltage terminal 30: 12.4 V
Control Module temperature: 9 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000119142016
Coding: 011D07200000453005080000
VCID: 44D1455C7E90ED6A6BB-8010
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0157380937
Coding: 01861E3A28B9500082A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Serial number: 213119111
Subsystem 2 - Part No: 1K0 951 605 C
2 Faults Found:
00165 - Switch for Transmission Position P/N
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 206163 km
Time Indication: 0
Date: 2023.04.04
Time: 13:21:40
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 94
Mileage: 206373 km
Time Indication: 0
Date: 2023.04.12
Time: 13:51:59
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000119441835
VCID: 3B233EA0036E92921A1-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11815006C4 Dataset Number: A001
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Revision: -------- Serial number: -------------- Dataset Number: 7P0036v____ 0009
Coding: 010E00000F000400
ASAM Dataset: EV_HeadlRegulVWAFS 005006
ROD: EV_HeadlRegulVWAFS_VW52.rod
VCID: 7CA1FDBC466055AA53B-8028
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 130000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 130000
Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H52 0133
Revision: AB001007 Serial number: 156HU0B7546010
Coding: 020007020100000001
VCID: 2411E5DC9ED0CD6A4BB-8070
Part No SW: 7P6 035 664 D HW: 7P6 035 664
Component: H-BN-NA H44 0706
Revision: -------- Serial number: 445I00B7519733
Coding: 010200050340E1ED01022F0E00000003F00001010000000000
VCID: 392F24A80952A08208D-806C
Subsystem 1 - Part No: 7P6 060 884 J
Component: NAR 2017/2018 1602
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Serial number: VWZ8Z9L79002VR
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
3 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 205081 km
Time Indication: 0
Date: 2023.02.13
Time: 09:19:39
Freeze Frame:
Text: DUA001,Front,M,0,0,6
03175 - Invalid Data Set
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 231
Mileage: 205081 km
Time Indication: 0
Date: 2023.02.13
Time: 09:19:37
Freeze Frame:
Voltage: 12.40 V
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 231
Mileage: 205081 km
Time Indication: 0
Date: 2023.02.13
Time: 09:19:38
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000119231135
Coding: 011C07200000253005080000
VCID: 3A2D3BA40C54AB9A017-806E
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000042597 Dataset Number: 7P6096v____ 0017
ASAM Dataset: EV_RDKBERU25 003006
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FDB4AB017F68EB2369-806A
4 Faults Found:
8397058 - Front Left TPMS Sensor
C1050 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 133
Mileage: 170621 km
Date: 2021.11.09
Time: 11:19:24
Vehicle speed: 10 km/h
Outside temperature: 15 °C
Reception level antenna 1: 830 mV
Offset level antenna 1: 740 mV
8397314 - Front Right TPMS Sensor
C1051 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 133
Mileage: 170621 km
Date: 2021.11.09
Time: 11:19:24
8397570 - Rear Left TPMS Sensor
C1052 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 133
Mileage: 170621 km
Date: 2021.11.09
Time: 11:19:24
8397826 - Rear Right TPMS Sensor
C1053 31 [009] - No Signal
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 133
Mileage: 170621 km
Date: 2021.11.09
Time: 11:19:24
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000155481635
Coding: 020D000000000000
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 224100029 Dataset Number: 7p0771v____ 0009
Coding: 0513314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000119228051
End----------(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V)-----------
Saturday,22,April,2023,16:20:16:45860
www.Ross-Tech.com
Mode 03: Emission related fault codes
Address 7E8: 1 Fault Found:
P0266 - Fuel Injector #2 (N31): Contribution/Balance Fault
Address 7E9: No fault code found.
