Lightbar, aux lighting switches
4.5K views 11 replies 6 participants last post by  PJMax
I've been slowly plodding away at making this car multifunctional for daily life, solo camping, and family camping.
The idea is to have a little as possible permanent attachments on the car so that for 'daily life' you would not know it was used for anything else. Why? I'm just weird like that.
I am doing up a roof rack to have lightbar, reverse/aux lights, ditch lights, and awning lights.
Hiding/integrating switches for this many operations was going to be difficult. (I also wanted a switch to turn on the Anderson plug for the camper)
I wanted something that looked reasonably factory, or at least we'll integrated, or pretty much hidden.
This is what I came up with. When I'm not camping I can close the lid and it's all hidden.
The light that normally lights the ashtray shines on the switches for night visibility.
This is the brains of the setup, the relays are in the rear RH panel in the back. I used the cd changer cable for signals as I have replaced the stereo.
Anyway, just thought I'd share.
As long as you don't profit from it. :sneaky:
If you're happy to cut out the bottom of the ashtray you could change the config and use larger switches.
I only wanted to cut a small hole to feed the signal wires through.
I have been thinking of how to put in some switches and integrate them well. the two empty banks up top on the console, next to the hazard switch looked appealing. get another one or two similar vw switches and use them, would look clean and original. just have to find the right kind.... otherwise what you have done is the way to go
PJ .. mate no one is weird ..... personal choices !!! and you blew the bomb !!!!!!!!!!!!! o_O thats a good thing !
DAMN ... i am seeing we myself and everyone in between loving this !!!!!! ;) ;)
Great for you for sharing here cant wait for more mate ;)
Bloody champion you are son !!!!!
So I've been tinkering more on this and think I can almost offer this switch panel as a product.
I was initially hoping to offer as a full kit with the switch panel and a relay panel, but now thinking just the switch panel might be the way to go.
The only thing I'm undecided on is the power wiring to the switch panel. Initially I was thinking to have screw terminals in the switch panel that could easily pick up cut ends of the cig lighter, but then I have to add a fuse to the switch panel that will either be a 'pimple' on the front of the switch panel, or not be very accessible (inside console). Or I make it with a lead long enough to pickup from from a piggy back fuse holder.
The production version will have 5 switches, but only 4 outputs.
I have made the right most two dedicated for lightbar/spot light operation.
The right most switch will allow you to select if you want the lightbar on or off with your high-beams. The next switch will turn the lightbar on manually with or without headlights.
The remaining three switches will have a spot for 12mm x 12mm stickers so you can customise to your situation.
The next question is whether there'd be enough interest to make it worthwhile?
Bare panel with no switches will be AU$80
Price point for the switch panel with switches, and 6m of 4core trigger wire will be AU$250
