I have a 2004 manual 2.5 tdi, Just recently when changing gear through 1st and 2nd upto 3rd gear and as I let the power off then re-apply the power I get a brief knock or judder sensation like as if I was going over a joint in a concrete road, this is getting progressively worse. It can be stopped if you really slow down the gear change and do it very gently.
The car now if driven normally judder/slips quite harshly when driving under medium load (in 2nd gear most commonly) the car will repeatedly judder once at regular intervals which seems like a rotational knock. It now feels as though something is slipping or taking up some slack somewhere.
I had originally wondered if it was prop, diff or driveshaft related but the more I read I am wondering if if is the dual mass flywheel slipping?
Another issue I have had on 4 or 5 occasions that I didn't originally think was related is when starting the touareg, the starter would kick in for about a second which wasn't long enough to fire the engine then would disengage but the starter would still spin until I turned the key off, it would repeat this 4 or 5 times before it would start, on one occasion it started when I rolled the car back a little.
Perhaps this could have been the start of a flywheel issue??
Has anyone else had any similar issues?
Thank you for reading ......
