21 - 22 of 22 Posts
Discussion starter · #21 ·
I don't have all the details for you, because mine is intact and not deleted. So get yourself a cheap PWM signal generator and find the correct wire, and experiment.... Or deal with the cluster error... Or get the tuna to fix it properly
I'll put it on the to do list.
Discussion starter · #22 ·
Who was the tuner? A proper tune should fully delete/turn off the emission portion of code in the ECM. Seems like they just disabled the DPF system from throwing codes/entering limp mode.
Your cluster is getting a message from the ECM that your DEF is low.
Malone, keep in mind this is a 2010 which is very different than the later cars.
21 - 22 of 22 Posts
