I got the ESP light on!
16K views 24 replies 8 participants last post by  Touareg MNE
Any thoughts? Suddenly appeared while driving. I tried pressing the button. With no succes. And i am driving now so can't write details
I will but won't be able to do it until January 3rd. Can this be related to the stepper motor?
I know about the sticky switch. Not the case here
Not yet, my mechanic opens his shop tomorrow
I called my mechanic just to get his advice, he mentioned the brake switch as Johan said. I am going in his shop tomorrow and will report back
Pulled out the center console, disconnected the switch connecnted it back again, cleaned the area around the button, and that didn't sort the problem out.. Battery is also only 9 months old, so that shouldn't be the cause.. It only remains to try aa VCDS scan tomorrow and see what error codes I aam dealing with..
Thanks Drag, will keep that in my mind. Where did you find that sensor?
Steering wheel problem.. I need wheel alingment.. I'll do it tomorrow and see if that turns the ESP light off
I noticed that I need to hold the steering wheel a bit to the right when i go straight. I hit a rock when off rroading 2 weeks and probably that messed up the front wheels
Yea that could do it i did some suspension work and the wheel was off enough that the esp light came on when i was going to the wheel alignment spot.
regards
Drag
Did the wheel alignment today, driven the car 5 miles and pushed the ESP button, the light was off.. Thank you all for the help
