If a Touareg TDI Executive can tow a maximum of 7,716lbs, it sounds like it can tow a 3 horse trailer that has a dry weight of 3, 170lbs and a GVWR of 7,000lbs. Each of the 3 horses weighs 1000lb. So tow weight with a trailer loaded with 3 horse and no tack or feed would be 6,170lbs. If I added tack and feed it would be a few hundred pounds more. And does not include weight of driver or passengers inside the Touareg.
Can this Touareg TDI, with a gvwr between 6,173 and 6, 305lbs, haul that much safely? If not, what would I need to aim for?
The GVWR are throwing me off as I don't fully understand their implications with different amounts, the higher one being the trailer. Does the Touaregs gvwr mean hauling this trailer isn't possible?
