1 - 3 of 3 Posts
carp
Discussion starter · #1 ·
My right headlight is out again. 3rd time. This time the bulb is good. The dealer removed the under dash shelf to check the control module. The number 3 pin on the elctronics contol module is burned out causing an open circuit. The recommended fix is to replace the control module, repin the wires and butt connectors. $645 on top of the $100 already spent. Ouch. I'm tempted to track down the parts and find a book or online reference to do it myself. Hence this is my first post.
Open to suggestion
carp
Check out the OEM parts catalog at 1stVWparts.com to see how much they want for it. You can also get an online subscription to the Bentley manual for the Touareg through Bentley Publishers.
Good luck!
Matt
1 - 3 of 3 Posts
