Hi all,
I always wanted the BMW halo rings look, so I got a used headlight from eBay ($50 shipped) to try it on. I also have those spider cracks in the driver side headlight, so I was hoping to get a clear lens with the eBay one. Well, I did.
I have to mention that the used headlight is halogen and mine are HIDs.
I believe the bucket is same, so the clear lens should fit.
I tried to follow the bake method, but the sealant is not very pliable at 250 F. It does soften a bit, but it doesn't allow for the two half's to be pulled apart.
The heat did help to soften the black plastic rim that I ended up lifting up with flat screwdriver and bending it back on itself until it broke off. I need to expose the end of the clear lens, so I could get under it to pry it off the bucket. It was hard, with multiple trips back to the oven I finally gave up and used heat gun instead.
Working the long sides first I worked the screwdriver under the lens until it separated. All that while heating it with the heat gun.
The good news is that this clear lens is a lot more forgiving than the rear lights and doesn't crack easily. The only thing to watch out for is to not to deform it much.
When it finally came apart I cleaned of the sealant since it can't be reused and the final assembly will have to be done with silicone.
The silver shroud comes off once I released it from more of the goop in the bucket.
I took measurement and the silver ring around the outer light, its 108mm OD and 74mm ID.
Ideal size of the ring would be 95mm. Most of the LED type rings are in full sizes (80,90,100,..), but I found 95mm cold cathode rings and ordered it today. I wasn't sure if I wanted the LEDs or CCFL rings, but I think the CCFL will look better.
We shall see.
To be continued ......
We shall see.
