HDD swap
43K views 65 replies 14 participants last post by  Nurbol
I have a 2011 exec, would love to have a significantly larger HDD. Has anyone ever done a hard drive swap in one of these?
Subscribed.
How hard is it to get the HDD out?
I thought about doing this, but then I got thinking about the possible cost of a decent, ruggedized hard drive that can take the vibrations of driving down dirt roads... needed so the drive keeps spinning for the GPS and music files. In comparison, a 32gb SDHC card costs about $30 (with taxes if you don't just buy the first one you see). As a result, I decided that some SD cards were an easier, cheaper and more reliable solution for me. Then there is the warranty issue too I guess.
SSD's are still relatively expensive compared to SD cards, but yes, that gets rid of the vibration concern.
As for the RNS-510 write-up, it looks really well done. For Canadian Touaregs, they all come with the RNS-850. I'm not sure where the hard drive actually resides in the RNS-850 system. The radio is in the right rear. Also, you'll need to clone your existing drive so that the GPS map data gets copied over to what-ever you're using. That's pretty simple though assuming you can get the correct cables and use your PC with something like PartedMagic.
I would pursue this if I knew the location of the RNS-850's hard drive. Just having a cloned safety backup could save a big future repair expense.
That guy's write-up on the RNS-510 is very well done.
EDIT: Page 5 of this Kufatec FISCUBE manual suggests the hard drive is in the glovebox near the DVD/SD drive: http://www.ima-box.de/support/manuals/fiscube_rns_850_en.pdf
Isn't the RNS-850 basically the same as the MMI 3G from Audi?
Google MMI 3G HDD swap and there seems to be enough information to put you on your way.
I would think pulling the unit out of the glove box and disassembling it will yield what you need.
I need to research the capacity issue more, need to make sure there's not some inherent limitation in the MMI, either software or hardware, that would cause problems with, say, a 128GB drive.
There's basically no vibration-protection in the MMI case design, so I'm sure the use of an oem automotive-grade hard drive is well thought out. SSDs, having no mechanical components, are less susceptible to vibration problems but a ruggedized automotive-grade SSD is probably the best choice, if not the cheapest. There are 64GB IDE SSDs on ebay for around $75. That seems to be the price floor.
Based on the $266 price I just found for a 128GB version of that drive at Amazon.com, I think your better off buying a few SD cards. Even if the price were half, I'd still have to go with the SD cards. The only advantage of this upgrade is being able to make a backup of the original hard drive. Probably better to replace the OE unit if it ever went bad because you'd likely get updated map data too.
From a "can I do it?" perspective though, its super cool.
The Super Talent SSDs with the "I" suffix on the part number are far more expensive. The 64GB "I" drive retails for over $1000. Their data spec sheet is confusing to me, not clear which drives have the greatly expanded operating temperature range but it's probably the "I" version. Still researching...
The new OEM unit seems to go for like $1800. The good news is I now have a used OE unit to play around with without voiding the warranty on my Treg's original unit...
There really is no point in getting any drive in the 60GB range since that's the existing drive size. At the cost you noted, I'm thinking that sticking with a larger disk based hard drive as opposed to a SSD might be a better way to go. Is there a larger version of the OE drive that could be used? The speed of the SSD will be wasted anyway, though with no moving parts I imagine its less likely to break or have issues in the vehicle.
I don't think so. It's the automotive grade drive that's the issue.
You could put a non-automotive rated drive and lower the cost substantially.
That adapter wouldn't fit. The drive plugs into a 90-degree right-angle connector that plugs straight down into the motherboard. It's very tight. I doubt any stock adapter would work without modifying how the drive is mounted.
I'll see about posting some pics of the disassembly phase and show how the drive is mounted and how to get it out.
Dredging this thread up because I really want to try replacing the stock 60GB hard drive with a 120GB SSD. There's lots of discussion in audi forums about this but not a lot of solid data. One guy claims he wrote a tool that resizes the file system to take advantage of a larger drive, but he won't share the tool. Worst case is you clone a 60 onto a 120 but it can only use 60. The upside is it would be a new faster SSD.
Comments & suggestions welcome. Tell us about your experience trying this. I have a sacrificial 2011 VW MMI with 60GB drive to use for testing.
The main point (for me) would be to see if the system operation is faster with an SSD.
But if I'm going to try it I might as well see if usable storage space can be increased too.
Sent from AutoGuide.com App
I would be very interested to see some documentation of the SSD conversion and the results. Is the standard HDD 5400 or 7200rpm?
