Harness jumper for front wiper motor
449 views 13 replies 5 participants last post by  chewblekka
Hello all,
I have an 04 Treg V6 that needs a new front wiper motor. I ordered what should have been a replacement. However once I got the old one out, I saw that the pins were different. The old one is 10pin, the new is 4pin. I'm looking for a female jumper harness but having as hard a time finding that as I did a replacement motor.
Any help would be deeply appreciated
I have no idea what you have, what you're not showing or telling, etc.
I can load up the parts cannon on your wallet if you wish, but it's not a good approach.
There's these things that were recently invented called phones.... if you can get your hands on one, call a dealer and give them your VIN.... they should be able to give you the correct part number so that you know what you need..... or slap them red oversized shoes & foam nose back on, and rip that motor out again.
I'll wait.
His method does seem to get people's brains working to be fair😂
owns 2013 Volkswagen Touareg V6 TDI
Looks like you received the REAR wiper motor.
there’s tons of FRONT wiper motors on eBay. They’re all the same 2003-2010.
It often happens with replacement parts... Have you looked to see if an adapter exists at VW or a harness supplier? Otherwise, a solution would be to reconnect manually with a universal harness, but it takes a little work. Maybe see with a breakage to recover an engine with the right connector. Good luck!
What kind of spam AI response is this?
