Gradual Power loss!?
1.1K views 9 replies 3 participants last post by  liquidlynx
Hey
Any clues why our 06 V8 driving down the street at 30 mph just suddenly lost all power gradually and then stopped. All electrics still on. Little to no (160-190) oil pressure on gauge. (It's never been over 190 really) I'd think obviously we'd have an oil pressure / pump issue or gaskets but there's no signs of leakage anywhere? Any help appreciated before I have to take the first step on a long road at the stealer, and he hooks her up for a vag code with some bad news.. :(
hi,
i think you mean oil temp gauge, confirm ?
cause as far as i know there is no oil pressure gauge on instrument cluster unless you have done some mods.
what does you battery voltage show? when did you replaced the battery? if you have access to VAG COM scan it first yourself before going to dealer,
any other symptoms to say?
Look more closely . . . that oil gauge is for temperature!
I assume you have checked the fuel gauge?!
Hey so not much to report. Vag-com plugged in came up with no codes and it hasn't happned again. Just taken her on a 14 hour trip from MS to VA and no issues at all. VW guys said all they could do was a 'wobble test' which basically means jacking the engine up half way off mounts and jiggling it whilst running to see if there's any chance they can reproduce the ailment somehow, I.e. Lose wire grounding etc. so...I guess I'll just have to wait and see! I'm finding a lot of little annoying issues with her though due to last owners treating the car like ****...got some work to do here!
hey thanks for update, i would just wain and see if something will gonna go happen, and about the rest of the repairs use search, sure you gonna find answers in most cases, if not start a new thread and make it informative for others to help you :) kind regards, Nikoloz :)
