Fuel Tank capacity - 2013 Volkswagen Touareg V6 TDI 7P MY13 4D WAGON DTV6cyl 2967cc DIESEL TURBO F/INJ 8 SP AUTOMATIC
8.4K views 17 replies 11 participants last post by  TommiT
Still having a load of neubie questions Apart from filling with fuel from near empty how can I tell if my tank is 100 ltr or 85 ltr Thanks for all the help so far.
Not sure what was available in Australia, but in NAR all Touaregs have a 100L tank. Best thing you can do is take your VIN to a dealer and have them print out your vehicle build sheet, which tells you exactly what equipment/options are installed in your specific vehicle.
I’ve definitely put in 90-95L till the auto-shutoff in my 2015 on several occasions.
In Australia, all V6 Touaregs were fitted with an 85 litre tank.
UNLESS you have the 180KW V6 engine WITH comfort package included. Then you would have a 100 litre tank.
Don't fill it from empty. Too much of a chance of overheating the in tank pump.
Fill it up when your at 1/4 of a tank. You should be able to calculate the capacity from there.
My '11 VR6 LUX has a tank capacity of just a little over 26 gallons.
I've got a North American 2014 with 100 liter tank. FWIW, the Touareg has by far the most hyper-accurate fuel gave I've ever seen on a car. When it says full, it is full. When it says 3/4, it is 3/4. When it says half, it is half, etc. I tested it by filling the tank when the gauge was reading different amounts, and it was spot on every single time. Assuming the 85 liter is similar, you can just top off the tank when it reads exactly 3/4 or 1/2, and extrapolate that to the full tank size.
I suspect the "gauge" is actually just a number calculated by subtracting fuel based on how much is pumped through the fuel injectors. And the float is only used to reset the level when you add fuel to the tank (if you add a very small amount, like 1 gallon / 4 liters, it won't register that any fuel has been added, and the gauge won't move). So the accuracy may be diminished if you repeatedly don't fill up the tank to full.
It's been discussed ad infinitum.
Diesel lubricity in the US in particular seems to be a problem.
Hot diesel not wanted by the engine is returned to the tank and isn't cooled sufficiently on the return without the contents of the tank itself helping.
HPFPs grenading are a known issue and the repair costs can be up to US$16,000
You can either treat 1/4 full as E to help or not.
