Update, even after removing the flap actuator and lubricating it thoroughly, the actuator would randomly refuse to unlock the flap. I found I could open the flap in that situation by giving it a sharp blow with the palm of my hand. Ordered a new one from eBay (approx US$ 50) and just fitted it to my 2013 7P. The new unit has a manual release cord attached. The 7P model does not feature a manual release, but I thought I would take advantage of the cord release so I found a way of running it from latch back through the rear panel to a small removable access point cover located in the luggage compartment. No holes drilled, no panels removed. I used a cable “snake” chaser and found a small opening from behind the fuel filler assembly into the interior towards the rear. Lots of jiggling to get the snake to pass (be careful as there lots of wires in there so don’t force anything). I had to add a length of cord to the supplied plastic cord as it was not quite long enough. I taped the loose end to the cover trim before clipping the trim back in place. In stall time 30 minutes. New unit works well.
