Frustrated
2K views 19 replies 8 participants last post by  Anchor Motorworks
Bought a Hex-V2. Downloaded everything and I ran the test and it states Interface found...Type Ross-Tech Hex-USB.....Status: Not plugged into car.
But when I plug it into my car, it states Interface Not found....
I'm just trying to get this test passed so I can register the darn thing...
It's like it won't register the cord...it shows it on Bluetooth and Other Devices but not in Device manager..
I attached pics...anyone know step by step to help me get this up and registered? Running Windows 10.
You can try running it with the orginally supplied software but it may not now work as the later genuine software may stuff the clones firmware. If it works is probably will not identify all the problems if the clone software is earlier than your car. I suggest you cut your losses and buy the genuine article direct from Ross-Tech
Ya you can't use genuine software with those clone dongles. I've had my clone for 6 years now. You must use the software they supply. If you can't use the mini discs, email the seller for a download link. Again, you CAN NOT use genuine rosstech software. You can not update the software either (unless you get a specific clone dongle with a specific chipset that is flashable to "legit" status, which takes some work and isn't for the computer illiterate).
Uninstall everything you just installed, reboot, then install the supplied software. It'll have a softloader that you launch VCDS from.
Reactions: Steve_L
Ross-Tech does not sell cables through mass market stores like Amazon or AliExpress- it's only authentic if purchased directly from them, or one of the few small enthusiast VW parts companies that distribute for them like IDParts.
It's one thing when companies are selling those generic blue cables that only work with old versions of VCDS/vag-com, but this is really egregious based on your photo- you've been scammed by a seller that is an outright fraud. With the sticker and molded case they are fraudulently claiming it to be a Ross-Tech product when it absolutely isn't one, and at $100 they are charging almost as much as the real thing, and 5-10x what a knock-off cable is worth.
Please submit a counterfeit claim through aliexpress- it is illegal for them to be selling counterfeit merchandise, and you should get a full refund. For what you paid, you can get an authentic used unit with 1-2 remaining vin numbers.
