Ok, I used an electric powerwasher to wash my ´04 V8 TReg including the grill area. I did a little extra time spraying through the grill to hopefully clean the radiator and oil cooler.
Anyone have a similar trifecta situation? What would you all think would be the top three steps to start the troubleshooting with?
Thanks for your input.Overview of hood sensor issues, ABS Crash Sensor and Ambient air temp sensor.
- The day after I noticed the external temperature was displayed higher than actual temp by 10 degrees and climbed to 104 deg ambient when it was a 75 deg morning.
- I disconnected the sensor behind the VW grill emblem, sprayed some parts cleaner on the terminals, blew with shop air and connected ohmmeter. I put it in a cup of ice and saw the resistance rise and then removed from ice and saw the ohms drop. I checked the wires at the sensor and they all looked fine. I followed the wires down a ways in the loom and still looked fine. Figured I would re-install. Unfortunately, it is still not working. It quickly shows rising temperatures far in excess of ambient. Before I replace it I want to see if it is related to the other issues.
- Also within a day, I had an airbag fault light. Faults 01738 (G283) Front drivers side crash sensor and 01739 (G284) Passenger side airbag crash sensor - static- closed. I don´t know where these are in order to check connections. Are they under the headlights? What´s the best way to get to them? I can find any pics or DIYs on them anywhere.
- Then a week later, I had a hood open light despite the hood being firmly latched. I had driven 20 minutes in the rain before it came on while I was driving. I checked the forums and saw multiple posts about the stereo not seated correctly. I removed the stereo as mentioned in some posts. My CD/Nav unit does not have the micro switch some said may be the issue. So I figured I´d check the hood latch assembly.
- I removed the grill, disconnected the harness to the hood sensor. The hood light dimmed a little. Hmmm. I connected the terminals in the harness with a piece of wire to see if that would turn off the hood light. It dimmed the light but didn´t turn it off. 2 things about this. I expected it would either turn off the light or not. If jumping terminals turned off the light, I would assume the switch at the latch was bad. If it didn´t, then I would know I had a problem somewhere else. The fact it dimmed threw me. When I removed jumper wire the hood light would brighten.
- I then removed the whole latch assembly to check it. With the harness connected, I could push the microswitch down with a small screwdriver and make the light dim, like when I jumped the harness terminals, but the lights would not go out.
- I followed the wires down the loom all the way to where the hood and ambient air wires meet a larger group of wires at a ¨T¨. I didn´t see any cut or exposed wires up to and in the ¨T¨
